Author: Subject: Right angle brake unions
Davegtst
posted on 31/7/10 at 11:06 PM Reply With Quote
Anyone know where i could get 2 right angle brake unions with an m10x1 male one end and an m10x1 female the other. Could do with some as the flexi hose to my rear caliper is at a bit of an awkward angle and seems a bit short. Been looking for a while and can't find anything.
[Edited on 31/7/10 by Davegtst]
blakep82
posted on 31/7/10 at 11:10 PM Reply With Quote
send russ bost a u2u, get him to make you up some new hoses
he should be able to make you the adapters if needed though. even if it was a 90 degree union, 1" of hose, and then the female end?
though, if he was to make up an adapter, you'd be as well to just get a new hose made up instead
[Edited on 31/7/10 by blakep82]
________________________
jambojeef
posted on 31/7/10 at 11:11 PM Reply With Quote
Rather than use male 90 degree - how about a banjo fitting instead?
Davegtst
posted on 31/7/10 at 11:16 PM Reply With Quote
It's not a major problem just would make it sit a bit neater. Can you get banjos for sierra rear calipers? What do others do with MK indy R's, seems like the rear hoses could do with being an inch or two longer.
MakeEverything
posted on 31/7/10 at 11:17 PM Reply With Quote
Bloody hell, youre still up looking for these?
Banjo's might not be such a bad idea...
No, not the deliverance type either. - You aint got such a pirty mouth.... lol
Kindest Regards,
Richard.
blakep82
posted on 1/8/10 at 06:57 AM Reply With Quote
not sure if it's just my sierra calipers, but unsure if the body of the caliper is smooth enough for banjo fittings?
MakeEverything
posted on 1/8/10 at 08:07 AM Reply With Quote
Try RS Components
Kindest Regards,
Richard.
MakeEverything
posted on 1/8/10 at 08:12 AM Reply With Quote
The bottom one Here
Kindest Regards,
Richard.
Davegtst
posted on 1/8/10 at 02:01 PM Reply With Quote
Unfortunatly they are the wrong thread mate but thanks anyway. Thats the sort of thing i need though.
posted on 1/8/10 at 03:54 PM Reply With Quote
It would be easier to change the angle where they attach to the solid line by bending the pipe and bracket.
Davegtst
posted on 1/8/10 at 08:58 PM Reply With Quote
The reason for the elbows is because the hoses don't quite reach the chasis. I can make brackets that makes he copper pipe meet the flexi's it would just make it look neater, i guess it would never be seen though.
