Author: Subject: Alloy sierra rear hubs
v8kid
posted on 3/8/10 at 03:14 PM Reply With Quote
The sierra rear hub bearing carriers are seriously heavy.
Does anyone have experience in getting castings made in aluminium? Costs?
I presume there would be a minimum run so is anyone else interested in bare castings/fully machined versions?
[Edited on 3-8-10 by v8kid]
You'd be surprised how quickly the sales people at B&Q try and assist you after ignoring you for the past 15 minutes when you try and start a chainsaw
blakep82
posted on 3/8/10 at 03:17 PM Reply With Quote
did the top gear caterham have them on the show when they built one at knockhill?
________________________
v8kid
posted on 3/8/10 at 03:20 PM Reply With Quote
Did'nt know that I'll google it
Minicooper
GB engineering alredy do a lightweight version
See here
http://www.berrisford.co.uk/product_info.php?cPath=42_51&products_id=122&osCsid=256cd6sk2lafhbb80pv15ieuo7
v8kid
posted on 3/8/10 at 03:21 PM Reply With Quote
Brilliant! You can always depend on Locosters
blakep82
posted on 3/8/10 at 03:23 PM Reply With Quote
this one comes with bearings already pressed in by the look of it
https://www.caterhamparts.co.uk/product_info.php?cPath=99_149&products_id=3783
[Edited on 3/8/10 by blakep82]
CNHSS1
posted on 3/8/10 at 03:28 PM Reply With Quote
quite a number available thru the autograss sources, disc and drum and granada too, BP Grassing nr Beds do some too
Gary 7
posted on 3/8/10 at 03:41 PM Reply With Quote
Some more here.
http://www.drdracing.co.uk/Chassis_Components.php
v8kid
posted on 3/8/10 at 03:58 PM Reply With Quote
Blimey I'm like a kiddy in a sweetie shop! These Autograssers have some desirable kit.
MikeFellows
posted on 3/8/10 at 04:02 PM Reply With Quote
these look like just the bearings from what I can tell.
ali f27
posted on 3/8/10 at 04:15 PM Reply With Quote
Hi purdy makes them we use them on race car fantastic weihgt saving Ali
omega0684
posted on 3/8/10 at 04:27 PM Reply With Quote
i'd be careful, none of the ones shown so far have the caliper mounting holes or are they not on the std sierra hub (somewhere separate?), on my cossie rear hubs there are intergrated into the casting
flak monkey
posted on 3/8/10 at 04:39 PM Reply With Quote
All the ones shown are drum brake type hubs then you just use an adaptor plate to fit the caliper to.
Sera
http://www.motosera.com
snakebelly
posted on 25/12/11 at 04:38 AM Reply With Quote
Anyone know if using these with bolt on drive shafts is an issue?
rdodger
posted on 25/12/11 at 10:52 PM Reply With Quote
I bought some.
They are for lobro/bolt in shafts ie disc brakes with the caliper mounted elsewhere. To fit them with the drum type or wilwood drum kit would take a lot of machining.
I sent mine back.
