Author: Subject: Pads for speed events
phelpsa
posted on 11/9/10 at 02:57 PM Reply With Quote
Currently running bog standard pads from the motorfactors in 205 calipers as I didn't want to splash out on fancy pads incase I found the calipers weren't useable.
Now I know the calipers are working fine what pads do people find work well on speed events? Obviously they need to work well from cold as there's no opportunity to get heat into them.
Dusty
posted on 11/9/10 at 03:16 PM Reply With Quote
Mintex m1144. Work well from cold and just get better. I swapped from greenstuff and wouldn't go back if you paid me.
JimSpencer
posted on 11/9/10 at 04:09 PM Reply With Quote
Hi
Definatly what Dusty said re Greenstuff..
Am alternative to the Mintex is Hawk Plus, can recommend those too.
GMPMotorsport
posted on 11/9/10 at 04:14 PM Reply With Quote
If want really good pads we use Carbone Lorraine, not cheap but an excellent pad.
www.gmpdevelopments.co.uk
www.gmpmotorsport.co.uk
ARDS Instructer.
RazMan
posted on 11/9/10 at 05:06 PM Reply With Quote
You won't get much better value than Mintex 1144 - they transformed my brakes after trying the Wilwood smart pads (which were scary)
Raz
phelpsa
posted on 11/9/10 at 10:55 PM Reply With Quote
Mintex 1144s it is then
Thanks!
Hammerhead
posted on 12/9/10 at 08:01 AM Reply With Quote
Or pagid blues
jeffw
posted on 12/9/10 at 08:32 AM Reply With Quote
There is a new Wilwood pad which is as good as the M1144 (CP20 I think). Not sure they will do it for anything but Wilwoods though.
Neville Jones
posted on 13/9/10 at 05:37 PM Reply With Quote
If you look at the Wilwood USA site, you'll find a couple of the Wilwood pads which make 1144's look like greased lard. Not cheap.
Also not stocked by RD, and best to buy from USA direct.
jeffw
posted on 13/9/10 at 06:41 PM Reply With Quote
BP20 are the ones I'm using and very good they are too
http://www.rallydesign.co.uk/product_info.php?products_id=15007
£48 from RD for the powerlite.
