Author: Subject: brake pipe routing
sdh2903
posted on 25/9/10 at 04:28 PM Reply With Quote
brake pipe routing
Quick question re brake pipe routing.
I have considered routing my brake pipe up to the top of the trans tunnel to get a bit more clearance around my reverse gearbox. I'm just a little concerned about routing the pipes "upwards". Where the pipe may run it would still be 2" or so below the level of the reservoir.
Any views on this?
cheers
gavin174
posted on 25/9/10 at 07:08 PM Reply With Quote
my brake pipes run about 4" above the resrvoir..
because the system is "full" there is no problem..
just think of the brake pipes as solids rods...
you are not pushing up hill if that makes sense
