Author: Subject: What wheel stud length
Thinking about it
posted on 25/10/10 at 04:56 PM Reply With Quote
What wheel stud length is needed?
Front - Cortina hubs
Rear - Sierra
Wheels - RS style 4 spoke Laser wheels
liam.mccaffrey
posted on 25/10/10 at 06:35 PM Reply With Quote
Can't help with your specific question but I needed to lengthen my tina studs and swapped them for granada ones. from the scrappy. Cheaper than buying from rally design etc.
Hope that helps
Build Blog
Build Photo Album
big-vee-twin
posted on 25/10/10 at 09:10 PM Reply With Quote
I used 50mm ones Cortina Hubs Front Sierra Drive flanges on the rear and Alloy wheels fitted, you can actually measure your alloy wheel thickness and then add the thickness of Hub/Flange and then the thread depth you require for your nuts
http://www.triangleltd.com
