dilley
| posted on 29/10/10 at 02:33 PM |
brake fittings
I need to have some braided brake pipe hoses made, I am struggling to understand what fittings to ask for! I am running wilwood calipers up front with
the adapter supplied with the calipers...
I am running vw handbrake calipers on the rear(rally design)
I am running wilwood master cylinders including the clutch cylinder.
I need to know what thread these are?? do I order banjo fittings? and also waht size ithe thread/fitting on a busa slave cylinder?
Andrew...any help welcome!
matt_gsxr
| posted on 29/10/10 at 02:59 PM |
Talk to Russbost on here, he knows the sizes of everything and makes up hose.
If you do want to do it yourself, then the VW rears are a 12mm banjo, which is a difficult adapter to get.
Front Willwoods are simpler once you have the adapter and I think this is described in the rallydesign catalogue (or at least it used to be).
http://www.furorecars.co.uk/contactme.php
Matt
dilley
| posted on 29/10/10 at 03:31 PM |
Phoned him this afternoon, I'll be there tomorrow at 10 am and have them all done!! how is that for service????
YQUSTA
| posted on 29/10/10 at 05:27 PM |
I have some of Russbost's brake lines and can say they are spot on. I will be getting the rear done when I swap to disc's.
"If in doubt flat out"
Colin McRae
