Author: Subject: Possible braking issues?
Rallye_Mark
posted on 17/1/11 at 03:18 PM Reply With Quote
Hey guys, I'm wondering if I will have any braking problems using my set-up or if it could be worked with using specific master cylinders and a bias bar?
I'm running 240mm vented front discs and the slightly larger 253 solid rear discs from a Sierra under my 13's, what master cylinders will i need and will I be able to adjust the bias enough to pass IVA?
matt_gsxr
posted on 17/1/11 at 04:04 PM Reply With Quote
I had the same brake set-up, and had 2 equal sized master cylinders and a balance bar. SVA was fine.
blakep82
posted on 17/1/11 at 04:39 PM Reply With Quote
i've got a slightly smaller master cylinder for the front. got 0.65 for the front, and 0.7 for the back. discs are slightly smaller on the back too though
________________________
Rallye_Mark
posted on 17/1/11 at 06:22 PM Reply With Quote
Can you remember what size Master Cylinders you used? Also was the balance bar more one sized or close to the centre?
