Author: Subject: Maxi B/j and transit drag link
tilly819
posted on 23/2/11 at 11:27 AM Reply With Quote
hi all
does anyone now the range of motion +/- ????? Deg for the maxi lower ball joint and transit drag link used on many kit cars????????
thanks tilly
F20C Haynes roadster 440 BHP/Tonne www.youtube.com/handmadeextreme
britishtrident
posted on 23/2/11 at 12:22 PM Reply With Quote
Transit drag link has restricted movement compared to the Maxi suspension joint. So the Transit part tends to be the limiting factor in how much suspension movement you can get.
How much articulation the Transit drag link has seems to vary between ball joint manufacturers as a drag link doesn't need much articulation in its original application, so I would advise buying one/two and measuring the angle it will move through.
[Edited on 23/2/11 by britishtrident]
[/I]
tilly819
posted on 24/2/11 at 09:02 AM Reply With Quote
ok thanks
tilly
