Author: Subject: dohc engine help pls
KECHICHE
posted on 15/3/11 at 08:23 PM Reply With Quote
hi guys can you pls help with this building a locost got the sapphire dohc injection unit to high for the bonnet could you pls edvice on what kind of carb i can use to gain some room to fit the bonnet, cheers Alex
norfolkluego
posted on 15/3/11 at 08:31 PM Reply With Quote
So is it the fuel rail thats too high for the bonnet?
KECHICHE
posted on 15/3/11 at 08:45 PM Reply With Quote
ill try to explane this propely the injection unit fitted to the engine in a angle that raising above the engine block,hope that helps,cheers
norfolkluego
posted on 15/3/11 at 08:52 PM Reply With Quote
Picture would help
KECHICHE
posted on 15/3/11 at 09:03 PM Reply With Quote
Hi sorry i could not load the photo but i managed to email it to you if thats ok ? sorry
SPYDER
posted on 15/3/11 at 09:05 PM Reply With Quote
Is it the engine pictured below? If so I would do a "cut and shut" operation to lower the plenum. I've seen it done on an injected Pinto engine. The DOHC can't be much different.
Bike carbs might be an alternative I suppose. You might contact Bogg Bros and enquire.
KECHICHE
posted on 15/3/11 at 09:07 PM Reply With Quote
yed thats the one,cheers nice one.
norfolkluego
posted on 15/3/11 at 09:16 PM Reply With Quote
Understand now.
As said bike carbs are one way to go, the other being Weber or Dellorto.
Bike carbs are a fair bit cheaper to buy but you'll need a manifold to go with them, around £300 from Bogg Brothers (that's what I paid).
If you bide your time on eBay you could maybe pick up a pair of second hand Dellorto 40s and a manifold for £250, I did when I had the Crossflow
[Edited on 15/3/11 by norfolkluego]
KECHICHE
posted on 15/3/11 at 09:22 PM Reply With Quote
thanks for your time ill shop arround.
SPYDER
posted on 15/3/11 at 09:45 PM Reply With Quote
Does anyone make a Weber manifold for the DOHC engine?
austin man
posted on 15/3/11 at 09:49 PM Reply With Quote
If I was at the engine install stage I would seriously consider a diffrent engine as the DOHC engine is a heavy unit and no much in the way of tuning a 2 litre pinto would give a bigger power output
norfolkluego
posted on 16/3/11 at 12:17 AM Reply With Quote
And a Zetec can be picked up for as low as £50 although you still have to spend the money on the carbs etc. you do get a better engine
KECHICHE
posted on 16/3/11 at 04:51 PM Reply With Quote
if i get the zetec engine will the t75 gear box bolt straight on? thanks
big_wasa
posted on 16/3/11 at 05:55 PM Reply With Quote
Yep.
There is nothing wrong with the twink IF you you can make all the bits to install it your self. If you want of the shelf parts get a zetec you wont be disapointed.
KECHICHE
posted on 17/3/11 at 03:10 PM Reply With Quote
cheers,that a nice looking set up there.
r1_pete
posted on 17/3/11 at 03:54 PM Reply With Quote
There is a carb variant of the twin cam, uses an odd ford/weber carb, I had one and was going to use it in an MGB, but to be honest, including buying a zetec it was cheaper than doing anything useful with the twin cam.
Less than £200 will buy you a Zetec bike carb manifold from boggs, and as there is no coolant to worry about in the manifold making your own is dead easy, just don't weld the runners on the wrong side of the manifold flange like I did......
[Edited on 17/3/11 by r1_pete]
KECHICHE
posted on 18/3/11 at 08:52 PM Reply With Quote
thanks for the edvice to be honist i not concidered anything yet just finding out the easy and qwicker option,it`s getting to much now on what to do,cheers Alex
