Antnicuk
| posted on 9/5/11 at 10:24 PM |
Can I Buy a Shallow Escort Steering Boss?
I have bought a snap off boss which bolts to the existing boss but this makes the steering wheel too close to me. The existing boss attached to the
column is 3 inches deep, maybe more? if i could get a shallower boss to bolt to the column, i could use my snap off boss but having browsed the net,
i cant seem to find anything.
The column is mk2 escort, i know sierra is a triangle column which is different but i dont know what other cars has the splined MK2 escort type
column.
any help appreciated
600 BHP per ton, Stylus Brought back from the dead! Turbo Rotary Powered!
lsdweb
| posted on 10/5/11 at 06:42 AM |
Can you fit a 'proper' snap off boss? One that is pinned and welded to the column rather than using another boss to attach to.
Just a thought
Regards
Wyn
RazMan
| posted on 10/5/11 at 07:23 AM |
There are low profile snap off bosses (about 25mm IIRC) available on eBay - I was considering one to make things easier getting in & out of the
car.
* edit - like this one QUICK RELEASE STEERING WHEEL HUB BOSS KIT | eBay UK
[Edited on 10-5-11 by RazMan]
Raz
Antnicuk
| posted on 10/5/11 at 08:18 AM |
i already the quick release boss which is a bolt on one so i would rather not change it for a weld on one. If it could just find a shallow
conventional one to go on the spline then i could use it.
