Author: Subject: Aquired some Fox Dampers
RickRick
posted on 31/5/11 at 07:23 PM Reply With Quote
I've got some dampers that may or may not be suitable for my car, anyone know anything about Fox Racing Shockers there 13 and 15" so 1" longer than the standard ones on the mnr, not measured yet but bearings at each end look vaguely the right size, there adjustable for rebound and compreshion and also have an air valve on the remote part
CRAIGR
Contributor
Posts 2769
Registered 30/8/05
Location Sussex
Member Is Offline
Photo Archive Go!
posted on 31/5/11 at 07:28 PM Reply With Quote
http://www.foxracingshox.com/company
Paul TigerB6
posted on 31/5/11 at 07:30 PM Reply With Quote
My mountain bike has Fox shocks front and rear. Think they started out in the motorcross suspension field.
Doctor Derek Doctors
posted on 31/5/11 at 07:35 PM Reply With Quote
Our formula Student Car used Fox Mountain bike shocks, they worked fine but the car was only 200Kg.
Could possibly work well on the light front end of a BEC?
RickRick
posted on 31/5/11 at 07:38 PM Reply With Quote
Yer my marin also has a fox float rear shock, i've even got a shock pump for them, no idea if it's the same sort of pressures as the car shocks i've just got, or what sort of pressure the car shocks would need?
just looked at the fox site, and can't spot any info on old products, not got anywere on google either yet
tegwin
posted on 31/5/11 at 10:45 PM Reply With Quote
The car shocks are not air... so dont try pumping them up.... arnt the remote reservioirs full of oil and nitrogeon for the dampers!?
www.verticalhorizonsmedia.tv
MikeCapon
posted on 1/6/11 at 06:32 AM Reply With Quote
Those look to me like an old Fox 'twin clicker' which was a pretty fair quality motorcycle shock.
They were imported into the UK by a pal of mine. If you want I could ask him for you?
The remote reservoirs are nitrogen charged with a floating piston to separate the oil and the gas. To check if you still have some pressure left just drop off the springs and push in the damper rod. It should resist and then push back out on it's own.
Don't whatever you do connect any kind of pump or airline to the valve in the remote. ther is so little volume of gas you will lose all the pressure.
HTH
Mike
