Author: Subject: Whats the best way to shorten a pair of half shafts?
Antnicuk
posted on 13/6/11 at 08:58 PM Reply With Quote
I need a pair of half shafts for a live axle shortening by 2 inches. Whats the best way to have it done and anyone know who can do it?
600 BHP per ton, Stylus Brought back from the dead! Turbo Rotary Powered!
Antnicuk
posted on 13/6/11 at 09:02 PM Reply With Quote
minitici
posted on 13/6/11 at 09:12 PM Reply With Quote
With 600 BHP per ton - I would get special one piece shafts made
Try GB Engineering.
AndyW
posted on 13/6/11 at 09:30 PM Reply With Quote
I used a company in downham market years and years ago to make some drive shafts for me for a nova (i know!) which i fitted a redtop in. This was before the likes of courtney even thought about it. Im think they were called carquip or something like that. I took them my old shafts and said same again but shorter, and there they were!
was along time ago tho'
[Edited on 13/6/11 by AndyW]
bi22le
posted on 13/6/11 at 10:13 PM Reply With Quote
Look in any kit car mag or PPC. There are always people advertising for custom made driveshafts.
HTH
Please read my ring story:
phelpsa
posted on 13/6/11 at 10:54 PM Reply With Quote
This was discussed on Retro-Rides this week, worth a look?
http://retrorides.proboards.com/index.cgi?board=techni&action=display&thread=105827
tony-devon
posted on 14/6/11 at 11:08 AM Reply With Quote
I go belt and braces on mine, my method is to cut the shaft in half, then turn down one piece by the amount that I wish to shorten it by, bore the opposite piece to suit, cross drill and weld them, fully weld round the V'd out join, then sleeve it
this is my home method of shortening them and keeping them straight, never failed me yet
although I never had serious amounts of power through them, but I was taught to do them this way years back by a guy that built big yank engined things, he built drag cars for a living and at one point owned the most powerful street legal road car in europe, so I kinda took his advice.
all depends on the budget, if you can afford one off or custom shafts, then go for it, me I cant so do them myself
heavy is good, heavy is reliable, and if it breaks, hit them with it
bartonp
posted on 14/6/11 at 12:27 PM Reply With Quote
Angle grinder.
Did you want to use them after too?
John Bonnett
posted on 14/6/11 at 12:44 PM Reply With Quote
I think the trick is not to cut and join but to cut to the required length and then machine the hub end of the shaft to suit. This will be at least as strong as the original shaft.
John
Steve Hignett
posted on 14/6/11 at 01:03 PM Reply With Quote
GB ENGINEERING Also known as Berrisford...
Antnicuk
posted on 14/6/11 at 08:22 PM Reply With Quote
thanks guys, i will look into it
