| posted on 26/8/11 at 02:04 PM |
How Many Magnets for Prop Mounted Speed Sensor?
Is there a 'usual number' for prop mounted speed-sensor magnets?
Also, how important is their spacing?
Cheers!
It's Evolution Baby!
Davedew
| posted on 26/8/11 at 02:08 PM |
My Acewell uses 1 magnet, but I think you can adjust it upto 4 if needed in the settings.
whitestu
| posted on 26/8/11 at 02:27 PM |
One on mine as well.
Seems to work fine.
Stu
snapper
| posted on 26/8/11 at 04:09 PM |
4 on a Telemetrix
Evenly spaced
I eat to survive
I drink to forget
david_hornet27
| posted on 26/8/11 at 04:17 PM |
One on my Acewell and it works great...
| posted on 26/8/11 at 04:51 PM |
Cheers guys... it's an Acewell sensor that I'm using for a VDO speedo, so I guess I'll start with one and see how I get on!
russbost
| posted on 26/8/11 at 06:20 PM |
You will only need one, even on a driveshaft one will give accurate readings from about 2-3 MPH & the prop is going to be going 3 & a bit
times as fast!
RickRick
| posted on 26/8/11 at 07:08 PM |
i started out with all 4 fitted to the prop, down to just one now, so top tips for making them stay put welcome. but apart from having to reset the
speedo i can't tell the difference in the readout
phelpsa
| posted on 26/8/11 at 07:14 PM |
Chemical metal!
stevegough
| posted on 26/8/11 at 08:16 PM |
I have got two, and they are fixed in place with a 'two - pack' type gunge which is, I suppose a sort of chemical metal like phelpsa
mentioned - its called...... Unibond repair express power putty ....and I got it from B+Q at peel corner, but I think the holyoake ave branch is
nearer you?
pic....
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
