geordielad
| posted on 11/11/11 at 08:15 PM |
triumph stubaxle
are the stub axles made of any special steel as i want to to make some so i can fit mx5 hubs to the spitfire stubaxle thanks in advance
Bare
| posted on 11/11/11 at 08:27 PM |
Good question Instinctive answer would be: Seriously unlikely :-)
I'm eventually doing similar. There are a variety of aftermarket stub axles from the Bespoke Triumph stockists and even Caterham itself...
Likely pricey but worth trying to glean a little knowledge from?
Beyond the axle to fit the new hubs.. what about the Caliper mounts? Given any though to that yet?
geordielad
| posted on 11/11/11 at 08:38 PM |
going to make brackets fit fit brembo 4 pots with 285mm discs
britishtrident
| posted on 11/11/11 at 09:07 PM |
You want to start with Vitesse/GT6 parts rather than Herald/Spitfire the stub axle is a larger dia and the caliper mounting brackets are bolt
on.
The GT6 also had bigger brakes.
Because they were used on so many racers mounting bells for big competition discs should still be easily available also aluminium hubs that can be
drilled to any pcd.
[/I]
clairetoo
| posted on 11/11/11 at 09:09 PM |
My guess would be that they are not ordinary mild steel - more likely to be EN16 or similar .
Its cuz I is blond , innit
Claire xx
Will weld for food......
geordielad
| posted on 11/11/11 at 09:14 PM |
thanks for the replies i dont want to use gt6 as they cost a fortune for large vented ones i want the mx5 hubs as they are 100pcd and then i can use
clio cup discs which are only £60 a pair for drilled & grooved
Bare
| posted on 12/11/11 at 03:34 AM |
Admirable sentiments... Once into the Mazda bits you are technological leagues beyond what Triumph even fantasized about.
But the Drilled part of your Brake desires suggests you really aren't fully aware of what you are up to... yet.
Lots of Reading & Researching is strongly indicated before you can go further.
[Edited on 12/11/11 by Bare]
Hector.Brocklebank
| posted on 12/11/11 at 10:48 AM |
I Think what British Trident is getting at is that you can use a standard Vitesse/GT6 stub (read that as readily available) with an un-drilled GT6
hub.
This setup would have bearings all-ready matched up, and you could then drill the hub to suit the MX5 PCD, and then use any disc/caliper combination
you desire.
And as noted already I too would avoid drilled discs, grooved to act as a pad de-glazer yes but drilled no.
[Edited on 12/11/2011 by Hector.Brocklebank]
Some people can never handle the truth and always try to shoot the messenger instead of taking an honest look in the mirror (its always easier to
blame another than to face reality), but secretly they wish they could grow a pair and be the messenger !!!
geordielad
| posted on 12/11/11 at 02:29 PM |
this is along the lines of what i was thinking but these are for rx7 hubs. mx5 would be pretty much the same
top: original Triumph spindle. bottom: new adaptor spindle to accomodate Mazda brakes.
cliftyhanger
| posted on 12/11/11 at 03:29 PM |
http://www.canleyclassics.com/?xhtml=xhtml/product/catkit3.html&xsl=product.xsl
obviously not a cheap option, but seems a good idea (ie pilfer it!)
Saying that, with very little lathework (open the bore up by less than 1mm, or machine the hub to do the same job) you can fit citroen xantia discs to
the GT6 or Spitfire hubs.
geordielad
| posted on 12/11/11 at 03:45 PM |
thanks for the link but a those prices no thanks (i want locost)
i can get the stubaxles made for £40 per pair & get mx5 hubs from scrappy for tenner
the other bonus is i am using mx5 rear uprights on the back so everything will be the same
[Edited on 12/11/11 by geordielad]
Neville Jones
| posted on 12/11/11 at 04:36 PM |
EN16 possibly(but brittle), EN8 more likely.
Nev.
