rdodger
| posted on 15/12/11 at 07:21 PM |
Sierra front wheel bearing
I have just changed the front wheel bearing. It is now a little stiff.
Is this usual and the new seal etc will loosen up a bit? Or am I doing it again?
Xtreme Kermit
| posted on 15/12/11 at 09:45 PM |
Front left on mine was tight when replaced.
It loosened up nicely, but I check it regularly in case it starts having a problem.
rdodger
| posted on 15/12/11 at 09:47 PM |
Good news. Thanks.
adithorp
| posted on 15/12/11 at 09:49 PM |
They can feel tight especially if you trying it with the bare hub? It'll free off with use.
...it would help if you had a wheel to borrow and try on it... oops!
http://jpsc.org.uk/forum/
rdodger
| posted on 15/12/11 at 09:56 PM |
Hi Adi
After building up both front and rear hubs I have measured the clearance of the calipers. The front Midilites take up less space than the Powerlite
handbrake calipers. So I guess that means they will fit.
Rog
