DRCorsa
| posted on 3/1/12 at 11:27 AM |
Sierra steering column - extension and mounting
Hello and Happy New Year to everybody!
I have an issue with my Sierra steering column. First of all it's the non adjustable type (with the alloy bracket) and i wonder if this is going
to work on the Roadster chassis.
Secondly i have made a probable mistake...
I have cut the column at an incorrect point. Not at the front near the rack but more rearwords, as you can see in the pictures attached. What i plan
to do now is to extend the column by using a steel tube with 26mm internal diameter and 30mm external. The circular section near the point of my cut
is 26mm, so i can extend it by using a piece of 30mm/26mm tube. And then i plan to mount it on the drivrer's bulkhead using a 30mm bearing, like
the one in the link:
http://simplybearings.co.uk/shop/p22815/SBPFL206+Oval+2+Bolt+Pressed+Steel+Bearing+Housing+with+30mm+insert/product_info.html
The big question is: Do you think this is a safe design (since the welding will be safe and strong anyway), or am i playing cards with the devil?
I hope i won't need to buy a new steering column..
whitestu
| posted on 3/1/12 at 11:55 AM |
If I'm understanding correctly I ccan't see why you would have a problem. My MK column is just extended with a pirce of tube welded on to
the Sierra column.
Stu
DRCorsa
| posted on 3/1/12 at 12:02 PM |
the Sierra column.
Stu
Hi Stu,
Yes, the normal practise is to extend the column by cutting it and welding a tube over it. But i think that i have cut the column at its collapsible
part (you see the triangle section covered by white plastic inside). Would this be a problem?
| posted on 3/1/12 at 07:28 PM |
As you say you have cut the collapsable section of the column . IMHO I doubt if it would pass IVA if any repair was spotted during the test
DRCorsa
| posted on 3/1/12 at 07:40 PM |
Yes, i have cut the collapsible part of the column but the column will remain collapsible after welding the extension tube! The inside triangular
shaped tube will still be movable in the occasion of a collision, is that right?
[Edited on 3/1/12 by DRCorsa]
