femster87
| posted on 29/2/12 at 10:44 AM |
Double fuel line clip
Hi guys am after a double clip that can be used for both my fuel lines. I have seen some but they all need about 8mm holes in the chassis rail to
mount them . are there any clips that would be a bit neater, I currently have the 3.2mm holes for the rivets. I want to use this but dont mind opening
them up a bit further. but not 8mm each.
loggyboy
| posted on 29/2/12 at 10:58 AM |
Can you not just rivet 2 Pclips per hole, 180 degrees opposed?
femster87
| posted on 29/2/12 at 11:06 AM |
I could but with the current layout the bottom pipe would be touching the handbrake bracket in the tunnel. due to the length of the neck on the
p-clip. if you understand what i mean. Just thought there might be an easier/neater solution out there
thefreak
| posted on 29/2/12 at 01:57 PM |
HEL sell these. Have a look here:
http://helperformance.com/store/product_info.php?cPath=10&products_id=3534
russbost
| posted on 29/2/12 at 02:05 PM |
That's a rubbish pic of the HEL unit, I have some of the HEL ones in stock in blue anodised ali £4ea plus P & P, they look a lot better than
that pic does, if I have a pic will post it in a bit.
russbost
| posted on 29/2/12 at 02:11 PM |
There you go
[img]
[/img]
[img]
[/img]
I think that's a slight improvement on the HEL pic!!!
loggyboy
| posted on 29/2/12 at 02:13 PM |
I would asume as they are quite wide they would give the same problem as using 2 clips though.
maybe these?
http://www.lrseries.com/shop/product/listing/5699/3839/1/ESR1373-PIPE-CLIP-DOUBLE-8MM.html
femster87
| posted on 29/2/12 at 02:56 PM |
Thanks guys,
Russ that is shiny but the price reflects it.
