DOEHEAD2
| posted on 25/8/04 at 02:19 PM |
capri laser diff?
can any one tell me what diff ratio a 2.0l laser capri has, as my pinto powered locost runs out of steam at about 95 mph, ive lifted car and turned
driving wheels and for one turn of wheel prop turns 1 3/4 times (cant get to turn prop input) this seems very low is it?
Dale
| posted on 25/8/04 at 04:24 PM |
if its not an lsd I think that ratio needs to be doubled as the other wheel will turn backwards. only lift one wheel and try it to verivy . 1.75
x2 around 3.55's (ish)I would guess.
Dale
twinturbo
| posted on 25/8/04 at 05:16 PM |
you won't get any accurate figures if both wheels are off the ground.
You can't gauntee that it will be double as drag between the prop input and drive output will affect the rotation to a degree
TT
MikeRJ
| posted on 25/8/04 at 05:23 PM |
TT
If one wheel is firmly on the ground, then you can guarantee that the observed ratio is exactly half what it actualy is. If one wheel is of the
ground but not braked etc. then all bets are off.
| posted on 25/8/04 at 06:05 PM |
2.0 Capri diff.
The one I found had the ally tag still on it reading 3.44:1. Have you got a 4 or 5 speed box?
DOEHEAD2
| posted on 26/8/04 at 07:11 AM |
i have a type 9 5 speed gearbox (possilbly out of granada dont know !)
Rob Lane
| posted on 26/8/04 at 07:38 AM |
What size wheels are you using? 13 inch?
95mph at what revs? If it's around the 6k mark then it sounds like a 4.1 diff is in there.
Higher ratio than 3.5 is hard to find.
DOEHEAD2
| posted on 26/8/04 at 03:41 PM |
wheels are 15" and approx revs at 4500!
ady8077
| posted on 26/8/04 at 03:46 PM |
Hi
Hows your engine running? I'd have thought it would rev higher than 4500
Adrian
