DaveFJ
posted on 3/9/04 at 02:29 PM |
Refurbishing Princess 4pot calipers
I have now got hold of a set of Princess 4 pot calipers off ebay (£37 )
They are pretty shabby and in need of a refurb...
Question is this - What do I need to do / check?
I have my eye on a refurb 'kit' but I think this is just a bunch of O rings - do I need more ?
Should I replace the bleed nipples as a matter of course?
Not sure if they have a spacer for vented discs - will get/fit one if not
Dave
mookaloid
posted on 3/9/04 at 03:13 PM |
IMHO you will need at least the rebuild kit, the chances are the nipples will be seized so be very careful about taking them out (if you shear it off
it is just about game over for the caliper) maybe new pistons also.
They should be spotlessly clean before reassembly (blow them out with compressed air)
HTH Mark
[Edited on 3/9/04 by mookaloid]
Jermyn
posted on 3/9/04 at 03:29 PM |
removing caliper pistons
I learned the hard way with calipers and pistons.
Blew my first set out with compressed air damaged one of the pistons. Other one didn't come out until I plugged the hole on the other side. Then
managed to blow out the other right into my fingers OUCH
Decided on my next rebuild to split the calipers. Bad idea, they never stopped leaking after that.
Finally a friend told me to use a grease gun. you should be able to thread it right into the caliper and you get 10,000lbs pressure instead of 135
from your air compressor. Made things much easier
If life is a race do you want to be the first one to finish?
mookaloid
posted on 3/9/04 at 04:04 PM |
Aplogies, I meant blow the calipers out with compressed air to clean them out
I use a foot pump to blow the pistons out - it gives better control.
I agree with Jermyn splitting the caliper is often not a good idea. best not to if you can get away with it.
Tip for getting siezed bleed nipples out tap them a few times with a hammer before loosening. it will flatten the end a bit but usually works. better
to replace them anyway.
Good luck
mackie
posted on 3/9/04 at 04:17 PM |
To get old bleed nipples off I used copious amounts of heat and wd40 and even filed down the mangled head to allow the next spanner size down to fit
nicely.
I split our M16 calipers and kind of wish now that I hadn't. We do have the O-rings required but various people have said that the bolts used
are stretch bolts and can only be torqued up once.
James
posted on 3/9/04 at 04:23 PM |
Can you not buy replacement stretch bolts?
James
DaveFJ
posted on 3/9/04 at 07:39 PM |
Fortunately a freind if mine has offered the services of his aircraft systems hydraulic servicing bay.........
so I guess i just need to clean them up then supply him the seals and a crate of beer
Cheers for everyones advice
Dave
MikeRJ
posted on 4/9/04 at 02:01 PM |
I got a set of Princess calipers, but I am wondering if it's really worth using them? They are unbeliveably heavy, and whilst I'm not at
all worried about adding a few kilos here and there, the weight is in exactly the wrong place.
The standard Cortina brakes were never tarmac rippling monsters, but should work well enough in a locost. Thoughts?
phelpsa
posted on 4/9/04 at 04:00 PM |
Their not that much heavier than the M16s.
Adam
Steve Hnz
posted on 5/9/04 at 08:13 AM |
Des Hammil in his book "Building & Modifying Kitcar Suspension & Brakes" makes the point that the Princess calipers are very
little heavier than the M16 calipers & defintely worth it for the extra retardation, especially if any track work is contemplated. The front
brakes on a clubman do most of the work&, as he says, drums are adequate for the back, but the extra pad area & more efficient application of
same with four pistons as against two is well worth it. For the record, I`m going Princess.
DaveFJ
posted on 5/9/04 at 08:20 AM |
Out of interest..
The seal kits I was watching on eBay went for £31 in the end plus p&p...
I paid £24 inc p&p for the same kits from Brakes International.
[Edited on 5/9/04 by protofj]
Dave
MikeRJ
posted on 5/9/04 at 06:46 PM |
quote: Originally posted by protofj
Out of interest..
I didn't know Brakes International sold seal kits. The online shop doesn't seem to list them, did you have to order them over the phone?
phelpsa
posted on 5/9/04 at 06:54 PM |
I am using princess 4-pots and they are only 0.2 of a kg heavier each.
Adam
DaveFJ
posted on 5/9/04 at 10:00 PM |
Re: Brakes international
if you look up the calipers in the online shop there is a button marked 'Associated items' IIRC which shows both the seal kits and spare
pistons (only 1 set of 4 pistons left though for my calipers)
Dave
MikeRJ
posted on 6/9/04 at 01:44 PM |
Thanks for that Dave!
ned
posted on 6/9/04 at 02:31 PM |
i've got m16's spaced out for capri vented discs, which may be overkill, but i'm waiting til the car is on the road, then i'll
go for some nice ally outlaws/brembos/wilwoods
Ned.
beware, I've got yellow skin
Terrapin_racing
posted on 6/9/04 at 02:36 PM |
Have you tried Brakes International in Rochdale (remanufactured calipers at realistic prices)?
www.brakesint.co.uk
