Author: Subject: XR 4x4 rear wheel bearings
blockhead_rich
posted on 12/9/04 at 07:10 PM Reply With Quote
Can anyone tell me the cheapest place to buy wheel bearing kits for a Sierra XR4x4 (ABS version) from, can't seem to find anything on the net?
Also, is there any recommended method of identifying if the ones I think I should repleace are actually knackered?
Rich
bob
posted on 12/9/04 at 07:14 PM Reply With Quote
Rich
I got all my bearings on ebay,i just did a search for sierra wheel bearings and up popped a load of em.
If i remember right i paid about half the retail price and that was inclusive of p+p
blockhead_rich
posted on 12/9/04 at 07:42 PM Reply With Quote
Hi Bob
Yep, already tried e bay, just thought that someone might know of another cheap source. Do yoy know if Cosworth ones would fit?
bob
posted on 12/9/04 at 07:47 PM Reply With Quote
Not sure if there is any difference in the cosworth and 4x4 bearings,best bet would be to check with your local ford parts/dealer.
andyps
posted on 12/9/04 at 09:17 PM Reply With Quote
Try your local bearing distributor - have a look in Yellow pages. I did post on here a full list of all the bearing part numbers - have a search for it.
BMF
posted on 13/9/04 at 08:28 AM Reply With Quote
Go to Camberley Auto Factors, they got them next day for me at about £20 per side if I remember correctly.
andyps
posted on 13/9/04 at 08:59 PM Reply With Quote
The best source for automotive wheel bearing kits is BRT Bearings. They make the wheel bearing kits for most of the reputable brands in the UK and elsewhere.
MikeRJ
posted on 14/9/04 at 08:31 AM Reply With Quote
https://www.sapmotorparts.com/shop/english/ list the 4x4 Sierra
blockhead_rich
posted on 15/9/04 at 08:31 PM Reply With Quote
Just thought I'd let you all know;
Cheapest place I found was GTS @ 18.50ea (+ vat) + carriage. Closely followed by http://www.buypartsby.co.uk/ @ £19.00 ea (+vat) + carriage.
My local Ford dealer wanted over £50!! - having a laugh or what?
Just need to sus out how to fit the b*****s when they arrieve> Anyone have any tips?
blueshift
posted on 15/9/04 at 11:04 PM Reply With Quote
That's been covered on here before, try a search (although the search feature is a bit pap). basically, lever out the oil seals, tap the old bearing outers out from the back of each one with a drift (there's a groove in the middle of the hub carrier that makes it easy), tap the new outers in *using the old outers* so you don't mark them, make sure they're all the way in, then whack the new oil seals in with a flat bit of wood.
