mads
| posted on 16/9/12 at 05:06 PM |
putting different sized stub axle on tripod driveshaft
Afternoon all,
I've found that the nearside push-in sierra driveshaft I have has the wrong thread on the stub axle i.e. the nut turns to the back rather than
the front of the car (no idea how this has happened). I have got a stub axle with the correct thread on it so want to swap this for the incorrect
one.
Problem arises that the "right" stub axle came off a driveshaft where the metal casing cover around the joint was smaller (in diameter)
than the one that is on the driveshaft that I am putting it on. Before I order a new casing and cut the one off, is this going to be an issue when I
come to fit it together?
I have checked the number of splines and they are the same so not sure why they are two different sizes.
mads
[Edited on 16/9/12 by mads]
We gain knowledge faster than we do wisdom!
Life is not a journey to the grave with the intention of arriving safely in a pretty and well-preserved body, but rather to skid in
sideways, thoroughly used, totally worn out and loudly proclaiming... "f*ck, what a trip!"
snapper
| posted on 16/9/12 at 05:42 PM |
The push fit hubs are handed
Nearside right hand thread
Offside left hand thread
Both shafts are different lengths
The simple option is to buy a secondhand drive shaft
You won't get the stub axle off easily
To replace the stub and the tripod joint will be the same as buying a shaft
You could drill and split pin what you have
I eat to survive
I drink to forget
mads
| posted on 16/9/12 at 06:04 PM |
Yep, for some bizarre reason my nearside (shorter driveshaft) has a RIGHT hand thread rather than a left hand thread. Am considering buying a
secondhand driveshaft but they are not cheap nowadays and I've already refurbed these so dont want to have to completely refurb another one.
The drill and split pinning could be an option, I assume it would be safe? Just dont like to have go this route if I can get the ends swapped over.
Edit: correction of what thread my NSR shaft has.
mark chandler
| posted on 16/9/12 at 06:28 PM |
Mine had LHT on the NSR, RHT on OSR, would it not just be easier to buy the correct nut from ford? It sounds to me that what you have is correct.
If you think they are the wrong way around did you swap the ends over when refurbing?
Regards Mark
mads
| posted on 16/9/12 at 06:44 PM |
I didn't do the refurb myself but I don't believe the ends were swapped over as the other side is OK.
Just noticed my reply above... my NSR has a RIGHT hand thread rather than the left hand which it should be.
clairetoo
| posted on 16/9/12 at 07:46 PM |
Sorry , but I've read this thread three times now........and I admit to being confused
What thread do you have on the left of the car , and what thread do you have on the right of the car ?
Its cuz I is blond , innit
Claire xx
Will weld for food......
mads
| posted on 16/9/12 at 08:22 PM |
Nearside: right hand thread
Off-side: right hand thread
clairetoo
| posted on 16/9/12 at 08:33 PM |
So.....whoever re-furbished your driveshafts swapped your OS end for a NS end - can you not just take them back and get them to sort it out ?
Claire xx
mads
| posted on 16/9/12 at 10:31 PM |
i assume you mean they have swapped my nearside for an offside end as the nearside should be a LH thread?
