beaver34
| posted on 13/10/12 at 12:40 PM |
spinning wheel stud
hi,
ive got a spinning wheel stud, wheel is stick on the rear of the car carnt get to the back on the stud
any tips for getting it out?
loosing the will to live, tried putting some force on the wheel and nipping the stud but that hasnt worked, also lowered car down to load it up but
that not worked either
thanks
blakep82
| posted on 13/10/12 at 12:57 PM |
if you take the rest out, and pull hard on the wheel so the wheel sort of pulls on the stud, is that enough to jam the stud with friction? while you
undo the nut, with a helper? or impact gun if you have one?
________________________
spiderman
| posted on 13/10/12 at 01:03 PM |
Tack weld a bar on the end of the stud to stop it spinning then wind the nut as far back as possible and hopefully you will have enough room to get
behind the nut to be able to cut the stud off, only works if you have open wheel nuts though.
Spider
loggyboy
| posted on 13/10/12 at 01:13 PM |
Worst case scenario, remove the hub nut, if you have calipers remove them, then pull the whole wheel and brake combination off and work from behind.
Mistral Motorsport
beaver34
| posted on 13/10/12 at 01:20 PM |
It's a axle to no hub but and carnt get the half shaft off for the wheel
I'll try borrow impact gun, wheel nut is longer than stud so not sticking out to weld onto, might have to dremel away at the nut to reveal some
stud
PAUL FISHER
| posted on 13/10/12 at 01:41 PM |
This is the method I used when I had the same problem on my Indy rear wheel stud, someone else pulling on the wheel with a long bar, at the same time
I removed nut with my airgun
snakebelly
| posted on 13/10/12 at 02:16 PM |
angle grind a slot into the centre of the nut as far as you can go, apply mr chisle to slot and give the good news with Tger Tool no 1, usually splits
the nut quite cleanly, use the biggest chisle that will fit.
HTH
bi22le
| posted on 13/10/12 at 04:36 PM |
HTH
This is what i did but its not as easy as it sounds. It took me and my friend all day.
Search for posts on here i had a 2 or 3 thread about it with lots of good ideas. I also posted my finished results.
Good luck. You cant give up, Whats the alternative ?!?
Please read my ring story:
renetom
| posted on 13/10/12 at 05:09 PM |
stud
Hi
Split the nut as stated by snakebelly, by far the best method
The stud is buggered anyway.
Worked for me several times over the years, nice cold chisel & a good steel hammer.
get another stud & spot weld it on the back , Job done.
Good luck
MakeEverything
| posted on 13/10/12 at 05:57 PM |
quote: Originally posted by renetom
Hi
Good luck
+2
Kindest Regards,
Richard.
aeromanboeing
| posted on 16/10/12 at 07:43 PM |
Some people should stick to production cars !!!
