Brett Jones
| posted on 15/10/12 at 01:18 PM |
Ford rear hubs
Hi,
I have a set of Ford rear hubs and I'm trying to work out which type they are, they have 27 splines for the stub axles. Does anyone know if
these are sierra or any model and which stub axles work fit these hubs?
loggyboy
| posted on 15/10/12 at 01:21 PM |
Photos would help.
Mistral Motorsport
Brett Jones
| posted on 15/10/12 at 02:54 PM |
loggyboy
| posted on 15/10/12 at 03:28 PM |
Their a bit too small to see!! lol
They do indeed look like sierra ones, hard to tell if disk or drum though, how long is the bearing seat?
Mistral Motorsport
Chippy
| posted on 15/10/12 at 04:33 PM |
FAR too big to be from a Sierra, most likely one of those huge yellow dump trucks,   Sorry Ray
Brett Jones
| posted on 15/10/12 at 05:10 PM |
Thanks for all the responses, the hub carries have the extra two lugs for the calipers so I think it safe to say they are for discs.
As the bearing are shot how would one determind which bearing are needed or are all sierra hub bearing the same?
PS sorry about the photo size, this was the first I'ever uploaded photos.
Chippy
| posted on 15/10/12 at 09:43 PM |
Hi Brett, joking aside, the hubs could be from either a Sierra, or I think that the later Grannies had four stud hubs, (early ones had five studs),
you would need to find out exactly which ones you have, but sorry I dont know what the spline count is for either. As for the bearings they can be
quite easily obtained in the correct size by just taking them out and putting a measure over them, once you know that they are the hubs that you
need. Hope that helps, even if just a bit. Cheers Ray
