Fiesta Mk3 Steering column
I need some advice, I'm using a Mk3 Fiesta steering column that has a DD shaft with a welded UJ and then a hex shaft (looks like a house when
looking end on) into the lower UJ before going onto steering rack spline.
What i want to do is replace the welded uj for a "DD" UJ but not sure if Ford used metric or imperial as 3/4" DD joints are
available in the USA but very pricey.
This is what i want to join together
This is the Hex shaft
This is the Fiesta Shaft
This is the Fiesta UJ to rack spline
[img] [/img]
So what I want is a DD UJ to join to the Fiesta shaft and then depending on the other end of the UJ I'll make up a shaft to then join to the
black fiesta UJ. Are there any supplies in the UK?
[Edited on 19/8/13 by JR.]
