mark_UK
| posted on 21/10/04 at 07:32 PM |
type 9,which car ?
Which cars were fitted with a type 9 box with the longer input shaft for the V6 cologne is it just granada`s ?(donor is 4x4 so i need another box)
also will the front end of my XR prop fit into it?
Deckman001
| posted on 21/10/04 at 07:37 PM |
I've heard some where that Capri 2.8i's had em as well
Jason
mookaloid
| posted on 21/10/04 at 07:41 PM |
mine came from an Xr4i
Mark
| posted on 21/10/04 at 07:43 PM |
yep, capri is the one usually quoted. The sierra XR4i v6 is 2wd, would this have type 9 or an MT75? IIRC mt's are 4x4 boxes, but i wouldnt
pretend to know for sure. hence might be a type 9 in there...
beaten by mookie...
[Edited on 21/10/04 by JoelP]
phelpsa
| posted on 21/10/04 at 08:00 PM |
MT75 & Type 9 available as 4wd.
V6 long input shaft:
MT75 2wd in scorpio, probably others.
Type 9 2wd in Capri 2.8, XR4i, granada.
mookaloid
| posted on 21/10/04 at 08:14 PM |
Sorry Joel,
But yep type 9, close ratio, long input shaft, onto pinto using alloy spacer between 'box and bell housing.
Mookie
