ceebmoj
| posted on 5/11/13 at 07:18 PM |
ford sierra drive shafts mixing bolt on and push fit
Does any body know if you can fit a push fit hubs on to a bolt on a ford sierra drive shafts? I ask because I have just found that the bolt on drive
shafts that fit my LSD diff do not fit in the dedion axle. I'm also trying to fit the rally design rear disk conversion.
I have found the folowing thread but ther does not seam to be a conclusive answer http://www.locostbuilders.co.uk/viewthread.php?tid=162473&page=1
AdrianH
| posted on 5/11/13 at 08:21 PM |
I have got rear drum hubs with push in shafts modified to take bolt on bits for a lsd diff, think is has to be the larger diameter shafts one can
get.
Did post on it at some time in the past prior to doing it
http://www.locostbuilders.co.uk/viewthread.php?tid=171931
found it
Adrian
Why do I have to make the tools to finish the job? More time then money.
ceebmoj
| posted on 5/11/13 at 08:29 PM |
Thanks I will get ordering the bits tomorrow. I was worried that I would need to change direction with the diff.
ceebmoj
| posted on 5/11/13 at 09:06 PM |
So if I have read everything correctly I need a set of push off ~27-28mm diameter shafts possibly fitted to a 1985 2.0L sierra. So where do you
measure the 27mm? is that just the fattest point on the drive shaft?
For example is this the correct type?
http://www.ebay.co.uk/itm/FORD-SIERRA-2-0-PETROL-DRIVESHAFT-OFF-SIDE-CV-JOINT-1982-1993-/141023774201?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=it
em20d5ac05f9
[Edited on 5/11/13 by ceebmoj]
AdrianH
| posted on 5/11/13 at 11:37 PM |
All I can suggest if you wish is to come and view, take measurements etc.
if you have the old tripod(e) push in shafts this will be a never going back experience, i.e. once you start to cut open the tins you can not get
replacements, make sure you have all the bits before you commence.
Adrian
I would also say no to that shaft as it looks like the thinner shaft.
[Edited on 5-11-13 by AdrianH]
scimjim
| posted on 6/11/13 at 12:11 AM |
quote: Originally posted by AdrianHif you have the old tripod(e) push in shafts this will be a never going back experience, i.e. once you start
to cut open the tins you can not get replacements, make sure you have all the bits before you commence.
push in CV joints come up occasionally - as do tins on their own (I have a couple on the shelf but have been converting most of mine to bolted flange
for Ford LSDs).
[Edited on 6/11/13 by scimjim]
Not Anumber
| posted on 6/11/13 at 11:49 AM |
No much better to leave it gong in the same direction really as otherwise you would have 1 forward gear and 5 reverses.
