daveb666
| posted on 21/11/13 at 08:47 PM |
Atlas Axle Movement Tolerance?
I'm making a boot over winter and want to make ure that I maximise the space as much as possible which means putting the boot floor as low as
possible and therefore close above to the rear axle.
I know there will be no hard and fast rule to this but how much will my axle move up when driving? 5cm? 10cm? More?
Ben_Copeland
| posted on 21/11/13 at 09:24 PM |
Sit on the back and push down hard. You should get a fairly decent idea how much it moves.
It really depends how hard your springs are
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
scutter
| posted on 22/11/13 at 08:01 AM |
It can't move more than the extension of your dampers. Normally 100mm total travel, so 50mm bump and 50mm rebound.
I'd think 75mm fromt he axle when at rest would give you 20-25mm of clearance.
Regards Dan.
