Xtreme Kermit
| posted on 20/1/14 at 06:41 PM |
Hubcentric spacers. Thoughts?
I need to space my rear wheels out to fit the tub a bit better.
I was thinking 25mm with both on hubcentric spacers.
Good idea/Bad idea?
40inches
| posted on 20/1/14 at 06:59 PM |
I would go with hubcentric and longer studs, shouldn't be a problem.
TimC
| posted on 20/1/14 at 08:10 PM |
I once bought some Eibach hubcentric spacers - costly but very nicely engineered.
Xtreme Kermit
| posted on 20/1/14 at 08:20 PM |
I was trying to be lazy a avoid replacing the studs...
loggyboy
| posted on 20/1/14 at 10:42 PM |
25mm is on the limit of needing Bolt on hubcentrics, IMO they are better than pass thru hubcentrics with longer bolts, but a fair amount dearer. 20mm
would be ok with entended bolts and JJC do a pair with bolts for about £30
Mistral Motorsport
rodgling
| posted on 20/1/14 at 11:25 PM |
I have 25mm bolt on hubcentric spacers for this reason, works great. Although I have killed a wheel bearing in a pretty short time period, perhaps due
to the extra load.
mcerd1
| posted on 21/1/14 at 08:49 AM |
dearer
yet I'm pretty sure its the bolt-on hubcentrics that are banned from several race classes due to safety issues...
long studs are the best solution
loggyboy
| posted on 21/1/14 at 10:18 AM |
dearer
Basic MSA regs ban extended studs:
5.8.2. Not be fitted with any wheel spacer exceeding 2.5cm in thickness or of less than hub diameter. Multiple or Laminated Spacers and extended
studs are prohibited.
Mistral Motorsport
Xtreme Kermit
| posted on 21/1/14 at 01:49 PM |
maybe I should back off to 20mm and fit longer studs in that case.
20mm should be enough to alter the appearance, soI guess I had better pull those hubs off and take 'em to a press!
loggyboy
| posted on 21/1/14 at 01:56 PM |
Are you attached to your wheels? Replacements with lower offset would have the same effect.
Mistral Motorsport
Xtreme Kermit
| posted on 21/1/14 at 05:16 PM |
mmm - now there's a thought... I always fancies a set of Team Dynamics 1.2s...
Cost is against me there though
