AntonUK
| posted on 16/2/14 at 07:20 PM |
Bush required
Hi All,
I need a new bush for one end of my Panard Rod.
OD is 1 1/32"
ID is 1/2"
Ive had a look round the internet and cannot find anything suitable... any ideas?
Build Photos Here
43655
| posted on 16/2/14 at 07:23 PM |
What material?
I could probably knock one out in delrin in work, but being a plastic it won't take any out-of-plane bending, however not sticky or squeaky
AntonUK
| posted on 16/2/14 at 08:33 PM |
Thanks, but it doe need a bit of movement. so rubber or poly is what I need.
Im getting the feeling I'm going to struggle with this one.
Build Photos Here
strikerbird
| posted on 16/2/14 at 09:09 PM |
Try these http://www.antivibrationmethods.com/product/bp-bush
Give them a call, sure they could find something.
SPYDER
| posted on 16/2/14 at 09:20 PM |
Hi there. I've got a 1 1/16" OD metalastic bush you can have. You might reduce its outer dia to suit. 1/2" ID. 35mm overall
length. Looks like this...
AntonUK
| posted on 16/2/14 at 09:36 PM |
Thanks, it appears they do list the correct item...
hopefully they are cheaper than the other possibility which is a bush from a caterham at £12 plus postage
Build Photos Here
strikerbird
| posted on 17/2/14 at 10:25 AM |
The 1 1/16" ones are the same as I used in my striker arms
Here http://bit.ly/1f5ylqZ
AntonUK
| posted on 17/2/14 at 02:12 PM |
Thanks all, I've managed to order one.
Will let you know how I get on.
Build Photos Here
AntonUK
| posted on 23/2/14 at 11:20 PM |
Quick update:
A 1 1/16 bush was sourced as multiple bits of research pointed towards it. Fitted today, twas really tight to fit but did go in with the help of mr
vice.
Thanks for the help all.
Build Photos Here
