Author: Subject: Geometetry settings Mk indy
chicade
posted on 22/2/14 at 11:12 PM Reply With Quote
I know there is lots of different options regarding settings but I am after a good starting point for fast road n track day use it's a old Mk indy and after a few winter mids is now sat on 13's and a048's rose jointed front wishbones I have set the ride height and am happy with the ride shockers are set 6 clicks from 0 what do you recommend toe in/out caster camber? Front n rear?
[Edited on 23/2/14 by chicade]
Matt21
posted on 11/3/14 at 07:54 PM Reply With Quote
on the mk website there is a manual for the build, near the end is the recommended base set up then you can fine tune from there
britishtrident
posted on 11/3/14 at 08:22 PM Reply With Quote
Toe should be parallel to a tiny amount of toe-in. on the front say. 0 to 0.125. essentially you want to as close to parallel as possible but avoiding toe-out.
At the rear a bit more toe-in aim for say 0.125. again avoid toe-out. at all cost, toe-out on the rear can be nasty.
Camber really depends on what use you put the car more negative camber on the front gives better turn in and less under steer at the expensive ofbtyre wear.
Try 1 degree negative all round.
Camber should be set before toe-in
[/I]
whitestu
posted on 11/3/14 at 08:48 PM Reply With Quote
Rear toe is fixed on the Indy unless you start shimming. Mine reads as 1.5 degrees.
I have 1 degree of toe at the front, 1 degree neg camber and 6.5 degrees of caster.
Stu
yellowcab
posted on 11/3/14 at 09:11 PM Reply With Quote
I have rosejointed rears so they're adjustable too
Front:
-2.0 negative camber
1.4mm toe in @ rims
4.5 degrees of castor
Rear:
-1.0 negative camber
2mm toe in @ rims
Thrust alignment taken from chassis
