Plunky
| posted on 16/4/14 at 01:51 PM |
Formula 27 ball joints
Hi,
Can someone tell me what ball joints the Formula 27 uses please?
I am after the upper and lower, part numbers would be ideal.
Liam
ali f27
| posted on 16/4/14 at 02:17 PM |
transit ball joints
ali f27
| posted on 16/4/14 at 02:19 PM |
Sorry didnt see you want top and bottom cortina tops
Plunky
| posted on 16/4/14 at 03:24 PM |
does it matter what mark of transit? are they all the same?
ali f27
| posted on 16/4/14 at 05:12 PM |
Hi cortina mk 3/4 upper and transit drag link mk 1/2
Cheers Ali
Plunky
| posted on 29/4/14 at 12:57 PM |
I've run into a bit of an issue with the cortina upper ball joints.
As you can see in the picture above the top of the new ball joints is a lot larger in diameter than the old one and due to this they won't fit
in the suspension arm.
My first guess is the ball joints have been revised.
Any ideas where I can get the older style ball joints from?
Thanks!
Plunky
| posted on 1/5/14 at 12:21 PM |
Anyone?
ali f27
| posted on 1/5/14 at 03:37 PM |
Bu88er cant get mine off at the mo to check will do a bit of research every one i get pictures of shows the ball joint end not the top i am sure we
got a new one for a guy who had a bump with his f27 do you know who built your car ykc or 1 of the others who owned the rights at that time
Cheers Ali
Plunky
| posted on 1/5/14 at 08:56 PM |
Havnt got a clue to be honest.
Looks like the ball joint has been revised anky car happens to use the older style.
Just trying to find a source of old stock!
teegray19
| posted on 1/5/14 at 09:02 PM |
i had this problem! chose to leave them until next year - let me know how you get on!
Built Formular 27 with 1600cc crossflow, 1700cc 0 miles crossflow, Kawasaki ZZR1100
ali f27
| posted on 1/5/14 at 10:11 PM |
One way would be to make 3 spacers and put longer studs in then lower the platform on your shocks to compensate i had to make offset plates to get
mine to self centre for iva
ali f27
| posted on 1/5/14 at 10:13 PM |
thinking about it i am sure there is enough meat in the rocking arm to grind out to suit the new ball joint
Plunky
| posted on 2/5/14 at 07:37 AM |
There is the option to mod the suspension arm, however, I'd prefer to find the right ball joints!
