daveb666
| posted on 27/4/14 at 09:23 PM |
obp pedal box brake switch
I need to increase the sensitivity of my brake light switch. I have an obp pedal box.
Can anyone help?
MikeR
| posted on 27/4/14 at 10:53 PM |
Put it on the front brakes, not rear. Put the switch under the brake line so it doesn't trap air.
jwhatley
| posted on 28/4/14 at 06:39 AM |
I use one of these, seem to be far before sensitive than the switch I used to have. Substitute one of your master cylinder banjos for it.
https://www.merlinmotorsport.co.uk/p/goodridge-3-8unf-banjo-bolt-with-brake-light-switch-g-bl775-03c?utm_source=Google&utm_medium=ShoppingUK&u
tm_campaign=ShoppingUK&vat=on¤cy=GBP&gclid=CLeHzsbIgr4CFefMtAodFlcAmw
daveb666
| posted on 28/4/14 at 10:57 AM |
Think the problem may be that I've recently changed the fluid so may have inadvertently trapped some air. I'll take a look tonight and see
which way up the switch is pointing.
big_wasa
| posted on 28/4/14 at 11:30 AM |
Size of the switch is m10x1 tapered.
Be careful screwing it in. Being tapered it can split the T piece if you over do it. Some suppliers will send you 1/8" ntp 27tpi as is very
close. But not exact.
Sold for the good old mini, mgb and many others.
[Edited on 28/4/14 by big_wasa]
