Jenko
| posted on 14/7/14 at 04:15 PM |
escort quick rack lock stops.
Done a search, but couldn't conclude on the correct answer.....How do you add them?, and what do you use? :-)
MY BLOG - http://westfieldv8.blogspot.co.uk/
prawnabie
| posted on 14/7/14 at 04:29 PM |
You can use split collars, but beware of the size as on one side of the rack the lock stop needs to go inside the rack on full lock and will really
limit travel if it is too big,
Andy S
| posted on 14/7/14 at 04:31 PM |
Jubilee clips do the job and different widths will give you different restrictions - on the rack just behind the knuckle.
mark chandler
| posted on 14/7/14 at 05:00 PM |
I used an inch of thick walled tube that fitted neatly on the rack, split it then used a jubilee clip to old it together.
Jenko
| posted on 15/7/14 at 06:39 AM |
OK...cheers chaps, will get on to this.
