Author: Subject: Front hubs, uprights
Gaz4562
posted on 21/7/14 at 03:54 PM Reply With Quote
Powder coat or paint the Front hubs, uprights of a sierra donor ?
alfas
posted on 23/7/14 at 03:36 PM Reply With Quote
powder...i would use it for as many things as possible...but(!!!):
you must find a company doing the coating process in the right way...otherwise it will flake after a short time.(like on TVR chassis)
the surface must be clean, oilfree, rustfree and dry. steel parts should be phospated b4 the powder is applicated. powder direct on the metal will sooner or later come off.
a trustworthy comany will do all above mentioned steps..but there are lots of "cheapish" working companies....
[Edited on 23/7/14 by alfas]
posted on 23/7/14 at 03:45 PM Reply With Quote
IMO paint them, use caliper paint after electrolysis to get rid of the rust. After all its just cosmetic and prepping them for powder to keep the paint out of the bearing faces will be expensive..
adithorp
posted on 23/7/14 at 03:52 PM Reply With Quote
Paint. Powder coat is great as long as it's perfect but it's difficult to prep and get right. Once it cracks on an edge, it peels of easily or lets the weather in behind. I'd go with Por15 every time now.
http://jpsc.org.uk/forum/
loggyboy
posted on 23/7/14 at 04:21 PM Reply With Quote
Paint THEN powder coat
Mistral Motorsport
Slimy38
posted on 23/7/14 at 05:31 PM Reply With Quote
Paint, on the basis that chances are something will happen to them (no matter how good the prep), and it's easier to repair paint than powdercoat.
[Edited on 23/7/14 by Slimy38]
neilp1
posted on 23/7/14 at 06:27 PM Reply With Quote
Paint for me as the amount of times I have knocked the hubs and uprights would hate to think I had them powder coated then chip some off.
Gaz4562
posted on 23/7/14 at 07:53 PM Reply With Quote
Although I have a mate who works at a powder coater, I think I'll paint them. That's once I manage to get the taper bearing off, that thing is stuck.
43655
posted on 23/7/14 at 08:40 PM Reply With Quote
Epoxy Mastic!
