Author: Subject: Indispension units (upside down)
madteg
posted on 5/9/14 at 08:21 PM Reply With Quote
Just thinking about building a towing dolly using suspension units upside down to get car lower. Will it work.
Sam_68
posted on 5/9/14 at 08:37 PM Reply With Quote
Originally posted by madteg
Will it work.
No.
owelly
posted on 5/9/14 at 08:44 PM Reply With Quote
I ran a pair on my boat trailer upside down to make it lower and it was fine. The suspension doesn't know which way round they are....
http://www.ppcmag.co.uk
Sam_68
posted on 5/9/14 at 08:55 PM Reply With Quote
Actually, the suspension geometry does.
The Indespension unit trailing arms are designed to droop 45 degrees when unladen, but to flatten out to about 13 degrees under normal static load, which means they give a geometrically rising rate (to add to the rubber's natural rising rate characteristics) within their normal working range.
If you simply invert them, they start out angled upwards at 45 degrees, and get steeper when laden, which means they will end up very steeply angled upwards under load, giving a geometrically falling rate, and end up almost vertical under any serious bump load.
Really not a good idea, honestly!
owelly
posted on 5/9/14 at 09:07 PM Reply With Quote
I stand corrected. But I won't be dashing out to change my boat trailer as it's doing sterling service for the past 15 years....
Sam_68
posted on 5/9/14 at 09:17 PM Reply With Quote
I suspect that if it's working fine, you must have a much higher load-rated Indespension unit than the weight of the boat you're carrying, hence keeping the deflections within a tolerable range... or you've rotated the trailing arm within the suspension rubbers to correct the trailing arm angle?
You can (or at least could - I don't know if the latest units still allow it) invert the mounting bracket so that it fits to the top of the chassis rail instead of underneath it (ie. underslung chassis) by rotating the box section of the trailing arm within the square section void in the rubber, so that you reduce the ground clearance whilst retaining the correct working angle for the trailing arm. This is the correct way of doing t, but it's certainly not the same as simply inverting the unit without changing the trailing arm alignment.
britishtrident
posted on 7/9/14 at 07:38 AM Reply With Quote
Actually the geometry of mounting upside down has exactly the opposite effect a a very steeply rising rate .
[/I]
Sam_68
posted on 7/9/14 at 08:27 AM Reply With Quote
Yes, you're right, it does.
My apologies - not concentrating!
... so less bad than a steeply falling rate, to be fair (albeit it risks higher instantaneous loads than the components were designed for), but it's still putting the working range of the unit somewhere it shouldn't be, compared to its rated load.
