Mark100
| posted on 20/4/15 at 08:28 AM |
rear wheel bearings
Just got my new rear wheel bearings from burton bt910 kits came with one seal each kit
checked with them and that's correct got my old ones ( what was left off them ) out and the new races in but the question is
since the old bearings had seals front and rear witch side do I put this seal on front or rear
Mark100
| posted on 20/4/15 at 08:31 AM |
or wheel side / prop shaft side
mcerd1
| posted on 20/4/15 at 09:12 AM |
For sierra / Granada rear hubs ?
They must have 2 new seals each side - just like the pic on burtons web site:
http://www.burtonpower.com/wheel-brg-kit-r-sierra-cosworth-xr4x4-abs-granada-mk3-brt910.html
Who ever told you they only need one is telling you lies...
mcerd1
| posted on 20/4/15 at 09:16 AM |
This is from the cossie manual, same type of hubs just a size bigger
b3ngy
| posted on 20/4/15 at 06:31 PM |
You should definitely have two seals, one each side of the bearing.
As mentioned loads of times, make sure you torque the hub nuts correctly....214lbft rings a bell but don't quote me.
Mark100
| posted on 20/4/15 at 09:11 PM |
cheers guys sorted it with burton they are getting me new sent out
