generaldogsbody
| posted on 27/4/15 at 10:50 PM |
Brake question
Both track controle arm bushes were knackered,i replaced them.On my mot failure list it says front brakes unballanced across axle,the brake pads are
fairly recent.Would the knackered track controle arm bushes cause the unballanced brakes.
mark chandler
| posted on 27/4/15 at 11:28 PM |
Afraid not, pull the pads and work the Pistons in the calipers until they move smoothly and while you are about it replace the brake fluid.
britishtrident
| posted on 28/4/15 at 06:02 AM |
As above sticky piston, or calliper slider or pad seized in calliper and don't use WD40 near any of the rubber seals it may solve the problem in
the short term but may well be what caused the problem in the first place.
[/I]
