furryeggs
| posted on 13/5/15 at 07:08 PM |
Identifying Diff & LSD
Could someone please help with a few questions.
-I've been trying to locate infomation on my Diff, I have managed to find codes off the diff casings. I was sold this as a 3.62 sierra diff? I
haven't opened the case yet to read and numbers on the crown gear but what I have found points to it being a Scorpio diff. The 2 different
numbers on the casing makes me think a different cover has been fitted at some point.
83BG-4025- BE ( from the main casing)
83BG-4033-BA (from the end cover)
Also D04 BA and C9J1A-1
-Rotating the drive flange both shafts turn in the same direction, does this mean its an LSD? It's closer to 3.9 to. (just under 4).
-And lastly without drive shafts, stub axles and drive flanges how can i tell if its push fit or bolt. At £40 it's not a massive issue if
it's a duff, but £40 is still £40, if i can use it on my Tiger will.
Many thanks.
| posted on 13/5/15 at 07:27 PM |
Just under 4 - 5 to 12 is indeed a 3.92.
And both outputs going in the same direction points to a viscous LSD.
What does it measure across the mounting points? 7" or bigger.
Mine was a 3.92 viscous 7" LSD diff.
It had bolt on shafts. Don't think any of the LSD riffs had push in shafts.
[Edited on 13/5/15 by coozer]
Matt21
| posted on 13/5/15 at 07:50 PM |
turning the drive flange, will turn both the outputs the same direction if its lsd or open.
you need to turn one of the output flanges
if the other turns the same way - lsd
if it turns the opposite way - open
it will also be fairly stiff if its a lsd, and pretty free if its open
if its an lsd, its bolt on shafts only
open diffs can be bolt on or pushin
as for the ratio, easiest thing is to just take the rear cover off
are the sierra and scoprio diffs the same? they look it from google images?
furryeggs
| posted on 14/5/15 at 09:55 AM |
The plot thickens, I have removed the end cover to access the crown wheel. there is a ford number stamped it.
83BG 4210 JF 3.92
this number is different to both the others, I have been down to where i used to work at sandicliffe ford and put the number through fords computer
and it doesn't match anything. The other numbers do, i seem to have a 7" sierra diff case with a scorpio rear cover but unknown
internals?
At least its confirmed a 3.92 ratio and its not LSD.
| posted on 14/5/15 at 10:42 AM |
Post a pic of the inside!
furryeggs
| posted on 14/5/15 at 03:25 PM |
Can't load a picture, its not letting me?
furryeggs
| posted on 14/5/15 at 03:35 PM |
[img] [/img]
furryeggs
| posted on 14/5/15 at 03:44 PM |
[img] [/img]
furryeggs
| posted on 14/5/15 at 03:51 PM |
try again.
[img] [/img]
[img] [/img]
[img] [/img]
[img] [/img]
hkp57
Everything is explained on the super 7th heaven web site about diff codes, drive shafts etc
http://www.super7thheaven.co.uk/components/sierra_rear_differential/
Fleet
SKC Raptor R - Hayabusa
Toyota C-HR Hybrid Limited Edition
Honda VFR1200 CrossTourer
DCT
Marlin Roadster 1800
Mercedes Vito 116 Sport
furryeggs
i give up
furryeggs
| posted on 14/5/15 at 04:01 PM |
Been there and checked. the code doesn't show anywhere, not even fords computer. I'm pretty sure its a 7" 3.92 open diff, 26 spline
with push in shafts. whatever the mistery code is/
thanks for the help anyhow.
