mikey p
posted on 21/7/15 at 09:32 PM |
Sierra based fabricated rear uprights
All,
Which kit cars use Sierra based rear hubs/shafts/brakes and are fabricated from steel?
Reason being is I'm building a RWD ford focus which currently has a Cosworth rear beam/7.5" LSD/bolt on shafts, and I want to change to
non trailing arm set up.
If i can find some rear upright which can be modified for the correct shock pick up and maybe strengthened if needed i will use these as a base.
That or just make my own.....
Many thanks!
Slimy38
posted on 21/7/15 at 09:57 PM |
That's just the Haynes roadster approach, so there are a fair few suppliers with the same design. If you're looking to modify it though,
perhaps start with this;
http://www.haycos.co.uk/?product=hub-kit
Then you can make the adjustments as you go?
adithorp
posted on 21/7/15 at 10:08 PM |
Haynes, Fury, Striker, MK, MNR, Mac#1... How long a list do you want?
http://jpsc.org.uk/forum/
Ugg10
posted on 21/7/15 at 10:29 PM |
Habe a look at the early fury irs which has a single lower wishbone and the a coilover from the top of the upright to a turret. May be easier to
manufacture and fit that a double wishbone version. The alternative is the venerable jag irs set up with inboard discs.
1968 Ford Anglia 105e, 1.7 Zetec SE, Mk2 Escort Workd Cup front end, 5 link rear
Build Blog - http://Anglia1968.weebly.com
mikey p
posted on 24/7/15 at 01:37 PM |
Yes that's how I want to do it with single lower wishbone and stut mounted to that.
Much like the old WRC escorts rear axes
https://www.google.co.uk/search?ie=UTF-8&client=ms-android-samsung&source=android-browser&q=cosworth+wrc+rear+beam&gfe_rd=cr&ei=yn
ixVcP4IrTj8wegkr-oCQ#gfe_rd=cr&imgrc=2R8f9F3_G3aBYM%3A
Can you still buy the early fury irs uprights?
