richard munnis
| posted on 22/9/15 at 02:53 PM |
4 pot willwoods
Hi folks currently running 2pot escort m16 capilers would changing to 4 pot willwoods make much of a difference as i do alot of track days cheers in
advance Richard
JAG
| posted on 22/9/15 at 03:16 PM |
It would definitely save a lot of weight.
M16's are about 4.5kgs each while the Wilwoods are less than 2kgs each.
The biggest drawback is the spongey pedal feel. Have a look at this HERE
Justin
rdodger
| posted on 22/9/15 at 04:01 PM |
AB Have a pair for sale going cheap!
https://www.facebook.com/abperformanceltd?fref=photo
richard munnis
| posted on 22/9/15 at 04:51 PM |
Yes had 4 pot willwoods on my mk the pedal always needed pumped after a long straight fid not change no matter what we done
atomic
| posted on 1/10/15 at 09:00 AM |
Not my personal choice for a 7 but they will be fine though you need to think about your install. You need to pay attention to the calipers piston
size and you master cylinder ratio. Seen a lot of people complain about their brake system all because they have just slapped it together with little
thought or consideration and expected to get last word in feel and performance.
The number of systems I've also seen installed without Residual Pressure Valves is staggering and these simple little devices make all the
difference.
I bet you the above posters system doesn't have residual pressure valves installed.
[Edited on 1/10/15 by atomic]
femster87
| posted on 1/10/15 at 11:45 AM |
difference.
Why would you need one?its disc brake not drums
