Author: Subject: What suspension is this?
Banana
posted on 16/8/16 at 10:23 AM Reply With Quote
Hi,
can someone tell me what sort of suspension this is?
Is just a dated coilover fitted to Locosts as an option?
Bluemoon
posted on 16/8/16 at 10:50 AM Reply With Quote
Normal locost "book" setup "unequal length double wishbone with coil over dampers". It has a better lower wishbone design than book to reduce bending load concentration on the lower bone known to cause lower wishbone failure.
Outboard shocks are not really dated, Caterham have stuck with this configuration for good reasons. Fashion is for inboard, but adds complication and weight..
Dan
[Edited on 16/8/16 by Bluemoon]
Banana
posted on 16/8/16 at 12:53 PM Reply With Quote
Thanks Dan.
I think its the diameter of the spring that threw me. Very large, when compared to aftermarket coilovers.
How would these hold up to track days do you think?
posted on 17/8/16 at 09:15 AM Reply With Quote
Can't be sure, but it looks like an older car to me.
Coilover shocks may have been a larger Ø back then?
Slimy38
posted on 17/8/16 at 09:34 AM Reply With Quote
It would probably still out drive a good portion of production cars, and you'd have a load of fun doing it.
As mentioned it looks like the standard suspension design, so you could always upgrade later if you find you're having problems.
Camber Dave
posted on 18/8/16 at 11:54 AM Reply With Quote
If it has a pin type upper mounting going between two rubber mounts it is probably Triumph Herald or Spitfire
