Shooter63
| posted on 8/11/16 at 09:01 PM |
lower ball joint conversion
I'm thinking about converting my bottom ball joints to rod ends, the pins I need for the conversion ( that go into the bottom of my front
struts) are available in 1/2" and 5/8" size, do you guys think both sizes will be OK strength wise.
Shooter
procomp
| posted on 9/11/16 at 12:22 PM |
Hi.
1/2" bore rose-joints usually with 5/8" thread but depends what angle you need on the rose-joint when fitted. Ie if wishbone is at 5 deg
to the pin you only have very small amount of angular travel left that may equate to only 1" of wheel movement. Cheapest version of high angular
joints are 5/8" bore and thread with an insert to reduce bore to 1/2"
Which conversion kit are you using. ?
Cheers Matt
Shooter63
| posted on 9/11/16 at 11:12 PM |
quote: Originally posted by procomp
Hi.
Cheers Matt
Hi Matt,
The only ones I can find are sold by a company on fleebay, I was hoping to use 3/4 unf rod ends as that's the thread in the lower arms, but I
can't find any with either a 1/2" or 5/8" bore, but as you have said and I didn't think of sleeve spacers might do the job.
As a side point the dampers and springs a had off you are working fantastic
Shooter
