Ron Lang
| posted on 29/3/17 at 09:36 PM |
Go Pedal
Can anyone tell me how you stop the accelerator pedal flapping around. I'm running the plenum which means there is resistance from the OEM
throttle body spring when pressing GO but nothing to stop the pedal swinging the other way. Is there supposed to be another spring?
Slimy38
| posted on 29/3/17 at 10:44 PM |
Personally I would suggest some sort of mechanical stop to prevent movement the wrong way? An L shaped piece of metal mounted near to the hinge
perhaps?
JAG
| posted on 30/3/17 at 08:43 AM |
I don't want to be harsh but this is a Kitcar - if it doesn't work how it should or how you think it should then fix it/change it.
You are in control
Justin
| posted on 30/3/17 at 11:03 AM |
perhaps?
Yup - fit an L shape piece of steel strip to the pivot point to act as a mechanical stop on the pedal travel.
