splitrivet
posted on 6/1/05 at 10:59 AM |
Sierra column mounting.
Decided to change the column I was using (Capri) to Sierra because it wasnt collapsible and relied on the wheel collapsible hub.
No probs in making up the top mounting but the lower bit ie compliance bush seems like it might be a pain hows everyone else got over this.
Bob
Mix
posted on 6/1/05 at 11:29 AM |
I am using a small piece of 3mm wall seamless tube which was very slightly smaller bore than the nylon bush. I turned the bush to size. The tube will
be welded to a suitable support when I finalise the layout of my steering.
Mick
DarrenW
posted on 6/1/05 at 11:56 AM |
Mine is almost same as Mix's. Tube welded onto chassis. Column bush locates inside this. Metal washer / retainer on back of bush to stop it
riding back up column towards steering wheel.
Rake adjustment also seems to work as well.
scutter
posted on 6/1/05 at 03:56 PM |
Bob, I've used the bush and bracket from Robin Hood, it's the orginal sierra bush mounted in a plate of 3mm steel, shouldn't be to
hard to make a similar design.
Image deleted by owner
Sorry if pictures crap, i'll take a closer one if needed.
ATB Dan.
johnemms
posted on 6/1/05 at 05:47 PM |
I used a spherical bearing for £10 from my bearing supplier... I think it was a 25mm inner.. does a great job, cant fault it especialy with tilt
steering
must put some pics in the archive....
phelpsa
posted on 6/1/05 at 05:53 PM |
Thats how I've done mine scutter
RoadkillUK
posted on 6/1/05 at 06:46 PM |
This is how we did ours.
it's a little lower than scutters (and yes the welding looks crap, bad day)
Roadkill - Lee
www.bradford7.co.uk
Latest Picture (14 Sept 2014)
Mark18
posted on 7/1/05 at 06:31 PM |
pretty much identical to how luego do it.
Mark
"I don't know what I may seem to the world. But as to myself I seem to have been only like a boy playing on the seashore and diverting myself
now and then finding a smoother pebble or a prettier shell than the ordinary, whilst the great ocean of truth lay all undiscovered before me." -
Isaac Newton
phelpsa
posted on 7/1/05 at 06:53 PM |
But Stuart Taylor do it the same as scutter and I.
Adam
splitrivet
posted on 9/1/05 at 11:21 AM |
Thanks for the input fellas,looks straightforward enough.
Bob
