Author: Subject: Sierra diff seized
EVO575
posted on 13/5/17 at 12:12 PM Reply With Quote
Sierra diff seized
Hi,
The diff has seized on my Tiger Avon hillclimber.The Casing is completely dry with no sign of leaking.Was working fine (or seemed to be) up to the last run on my last hill a couple of weeks ago.Whilst freewheeling down to the start line there was a whining sound that I thought was coming from the front which I checked and everything seemed to be OK - but thinking now must have been coming from the diff.After the run the I stalled the car a couple of times as it did not seem to want to go forward which I again thought was brakes.But no,it's the diff and now it's completely seized .I Has anyone came across this before and is it fixable? Thanks.
posted on 13/5/17 at 12:18 PM Reply With Quote
Hmm, front bearing overheat and welded itself up maybe?
Or the planet gears have dropped off the pins and jammed it up?
Take the cover off and have a look inside...
avagolen
posted on 13/5/17 at 04:55 PM Reply With Quote
What size / configuration is the diff?
I have a spare 7.5inch 3.9 Bolton shafts waiting for a new home.
The Answer for everything, but never the last word....
EVO575
posted on 13/5/17 at 05:27 PM Reply With Quote
Hi , it's a 3.62 7 inch bolt in shafts. Looking for a replacement if anyone hears of one !
Nickp
posted on 14/5/17 at 06:31 AM Reply With Quote
I've just taken a 3.62 out of mine to put a 3.14 in. So the majority of the 3.62 will be available.
I'm about to strip the LSD out of it to put into the 3.14 along with the lobro joints.
Depending what's wrong with yours I could probably make you up a direct replacement, whereabouts are you?
Ben_Copeland
posted on 14/5/17 at 07:30 AM Reply With Quote
I've been thinking of doing similar, damn I should have bought that 3.14 at stoneleigh for £100 !!
Ben
Locost Map on Google Maps
Enter Your Details Here
Nickp
posted on 14/5/17 at 07:44 AM Reply With Quote
£100?? You should've ripped their arm off mate!! I thought I'd got mine cheap
Ben_Copeland
posted on 14/5/17 at 09:14 AM Reply With Quote
Did have the cash, and had no history so it could of been knackered
Ben
Barkalarr
Contributor
Posts 945
Registered 14/3/12
Location Essex
Member Is Offline
Photo Archive Go!
Building: Caterham R300, Caterham Roadsport,Indy R1,Indy Zet
posted on 15/5/17 at 06:51 AM Reply With Quote
I have a 3.14 diff you can have for £250 and a 3.38 for £225
+ post.
Davelarcs
posted on 16/5/17 at 06:50 AM Reply With Quote
I've got a sierra diff & drive shafts, can't remember what spec, it was out of a shopping trolley version, so I doubt anything special, but you can have it for free if you come and collect it from near Swansea.
EVO575
posted on 16/5/17 at 09:35 AM Reply With Quote
Thanks Guys for the replys. The car was stripped this morning and discovered that it was the rear brake master cylinder that was seized solid and not the diff after all ! which makes me feel a bit silly and premature - bur will be easier to fix!
