Gwg555
posted on 24/6/17 at 08:39 PM |
Locost Diff Oil
Hi all,
Please can someone recommend the best diff oil to use on a 1.3 Xflow - locost race car, and where to purchase it from.
I've got a track day coming up and would like to top it up beforehand.
Thank you for you help.
Guy
posted on 24/6/17 at 08:41 PM |
Live axle should use EP 90 gear oil IIRC?
Gwg555
posted on 24/6/17 at 08:49 PM |
Thanks for the replay.
Would Halfords version be suitable?
http://www.halfords.com/motoring/engine-oils-fluids/gearbox-oil/halfords-gear-oil-ep-80w-90-gl-4-1l
Especially for track day use.
Guy
snapper
posted on 25/6/17 at 03:54 AM |
Check the bottle, they usually have recommended for Ford , Peugeot etc on the bottle.
Any gear oil will do as long as it's the correct viscosity.
Thing to check is if it's not getting to hot
I eat to survive
I drink to forget
britishtrident
posted on 25/6/17 at 06:24 AM |
Not just any gear oil it has to be an EP (Hypoid) GL-5 gear oil ---- EP90 or EP80/90 or EP75-90
EP gear oils have a high percentage extreme pressure additives to deal with the higher contact pressures in hypoid final drives.
This differs from normal sae 90 or 80/90 or 75/90 grade GL-4 gear oils used in gearboxes.
[Edited on 25/6/17 by britishtrident]
[/I]
britishtrident
posted on 25/6/17 at 06:28 AM |
Guy
Yes or the Comma equivalent
[/I]
