the_big_1
| posted on 30/6/17 at 06:22 AM |
Sierra Mushroom Inserts
Hi Guys,
Looking for recommendations where to buy the Sierra front hub mushroom inserts from?
I need a pair for my Haynes build (using the transit drag link ends etc)
Talon are £65 but struggle to get hold of them and worried never see them
Rally design are £19 but look like not offset?
Any other suppliers etc?
Cheers!
Nickp
| posted on 30/6/17 at 06:44 AM |
http://www.kitcardirect.co.uk/mk-indy-mushroom-inserts.html
the_big_1
| posted on 30/6/17 at 06:49 AM |
Great stuff!
I have asked them if the thread will fit the Ford transit drop link.
Cheers!!!
Schrodinger
| posted on 30/6/17 at 08:00 AM |
It's not the thread that you will need to fit but the taper
Keith
Aviemore
procomp
| posted on 30/6/17 at 10:28 AM |
Hi.
Just buy the rally design ones. Having the offset is a complete waste of time. Anyone selling offset inserts claiming to be for caster correction is
talking complete rubbish.
Cheers Matt
MikeRJ
| posted on 30/6/17 at 04:36 PM |
quote: Originally posted by the_big_1
Great stuff!
Cheers!!!
The taper (not thread) needs to be compatible with the transit drag (not drop) link. I suspect it probably is as most of the locost variants appear
to use the transit drag link.
Nickp
| posted on 30/6/17 at 05:01 PM |
quote: Originally posted by procomp
Hi.
Cheers Matt
Can you explain please? Just curious
40inches
| posted on 30/6/17 at 06:33 PM |
Hi.
Cheers Matt
The castor is taken through the centre of the top and bottom ball joints, twisting the offset insert doesn't alter that relationship.
It does however alter the Camber, can be used to fine tune. Or so it seems
procomp
| posted on 30/6/17 at 07:50 PM |
If wanting to fine tune camber you'd do it properly with an infinite adjuster on the thread of the joint NOT on the insert as both sides need be
set the same. Hence just buy the inserts with a central tapered hole.
Cheers Matt
Ben_Copeland
| posted on 30/6/17 at 09:07 PM |
Listen to matt (procomp) he does this for a living!
Don't need an offset mushroom !
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
the_big_1
| posted on 2/7/17 at 03:38 PM |
So the rally design ones at £19 are just as good as the MK ones at £49?
Does anyone know if they are tapered?
Ben_Copeland
| posted on 2/7/17 at 03:43 PM |
I've got Rally Design ones. Had them for 4 years no problems
Ben
Roadster
the_big_1
| posted on 2/7/17 at 03:45 PM |
Cheers Ben,
Can you remmber if they where tapered
Ben_Copeland
| posted on 2/7/17 at 04:04 PM |
Yes I believe they were
Ben
Roadster
the_big_1
| posted on 2/7/17 at 04:08 PM |
Great stuff!
I guess the offset ones give you a little bit more camber, but the top drop link should more than enough adjustment.
And it leans your hub back. (Don't see any benefit to that lol)
As said, castor is only through the centre axis of the alignment of the top and bottom ball joints so offset inserts have little to no effect
the_big_1
| posted on 2/7/17 at 05:55 PM |
Hi guys,
Just before I order, are these the right ones?
https://www.rallydesign.co.uk/product_info.php?products_id=13003
Ben_Copeland
| posted on 2/7/17 at 06:02 PM |
Yep
Ben
Roadster
the_big_1
| posted on 2/7/17 at 06:04 PM |
Great stuff!
Will order them!
