LBMEFM
| posted on 10/7/17 at 03:12 PM |
Bent chassis
Following a shunt to my n/s/front wheel of my MK Indy it has put a slight bend in the upright square section of the chassis where the round bar is
attached that comes up from the lower part of the chassis and the rear of the upper wishbone mounting is. Is the only option to weld in a new upright
section?
| posted on 10/7/17 at 03:51 PM |
I'd have thought a check on the chassis wishbone pick-ups to make sure there's no distortion would help. Worst case a rebuild with a new
chassis, otherwise cut out and replace the bent section as you suggest.
myke pocock
| posted on 10/7/17 at 06:14 PM |
Cut out and replace, no question about it.
Ben_Copeland
| posted on 10/7/17 at 07:26 PM |
Yep cut it out replace. Pretty easy tbh.
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
LBMEFM
| posted on 11/7/17 at 02:08 PM |
Thanks guys, it's stripped and ready to be welded in, as said pretty easy. How are you Ben long time no hear from you?
Ben_Copeland
| posted on 11/7/17 at 02:13 PM |
Good thanks mate, If you have any issues give me a shout ! I've got a decent MIG welder.
Ben
Roadster
LBMEFM
| posted on 11/7/17 at 06:35 PM |
Thanks for that Ben but I have got a mate who's a fabricator doing it for me. Look after yourself, all the best Barry.
