craigdiver
| posted on 10/7/17 at 05:04 PM |
Sump modification
Needing my BMW alloy sump altered to give more ground clearance. Anybody good at, and have the heavy duty TIG welder for welding aluminium? Or know
someone or a business that could do the work?
Craig
If it ain't broken, fix it anyway (just because).
Building - BMW powered Haynes Roadster/442E hybrid.
Volvo C30 T5 Polestar
Nickp
| posted on 10/7/17 at 07:41 PM |
A local engineers here in Barnsley did mine, cost about 20 squid.
Ask Froggy on here, he could probably do it for you.
Have you seen mine? Got some photos somewhere I think.
craigdiver
| posted on 10/7/17 at 07:55 PM |
Yeah, yours looks good, do you think the same guy that dine yours might be interested in doing mine if send it down and cross his palm with some
silver?
craigdiver
| posted on 10/7/17 at 07:57 PM |
What did you do with the dip-stick and oil level sensor that is mounted on the bottom of the sump?
Nickp
| posted on 10/7/17 at 09:05 PM |
Dipstick was fine and mine didn't have the sensor either. I took about 40mm off IIRC.
craigdiver
| posted on 10/7/17 at 09:09 PM |
Had a look through your build diary of the sump modification, doesn't look to bad to modify, might have a go myself fabricating the pieces and
get someone to weld it up.
