geoffxt
| posted on 24/7/17 at 06:47 PM |
Type 9 gearbox ratios
Are there any exterior markings on a type 9 gearbox which indicate what gear ratios are inside. If not how do you know what they are????
spiderman
| posted on 24/7/17 at 07:24 PM |
try this I found doing a Google search.
http://www.bearingkits.co.uk/How-to-tell-what-Ford-Type-9-gear
box-you-have/B19.htm
Spider
Ugg10
| posted on 24/7/17 at 09:34 PM |
Biggest differences are in input shaft length , i4 is short and v6 is long.
Other way is put it in 1st, turn the input shaft and count how rotations to get one of the output. More accurately count ten rotation and divide by
ten.
1968 Ford Anglia 105e, 1.7 Zetec SE, Mk2 Escort Workd Cup front end, 5 link rear
Build Blog - http://Anglia1968.weebly.com
mcerd1
| posted on 25/7/17 at 11:52 AM |
here's the 4cly version's dimensions and ratio's for comparison:
| posted on 25/7/17 at 05:01 PM |
Also don't forget the diesel type 9 has the long input shaft but a very low 1st gear which is totally useless in a seven type car
geoffxt
| posted on 1/8/17 at 08:42 PM |
Thanks for your input guys. It was very helpful!
